Tue, Oct 22, 2:16 PM CDT
Forum Moderators: wheatpenny, Deenamic Forum Coordinators: Anim8dtoon
Photography F.A.Q (Last Updated: 2024 Sep 18 12:22 pm)
Subject: Airshow Part2
TMGraphics ( ) posted Sat, 22 May 2004 at 11:12 PM ยท edited Tue, 22 October 2024 at 12:37 PM
Here are a few more images from the Airshow. (Used a 18-55mm, 80-200mm, and a 100-300mm lenses. Most sky shots were handheld at 300mm.) Thanks for viewing and comments. TMG
More...
TMGraphics ( ) posted Sat, 22 May 2004 at 11:14 PM
And one more. Thanks again for viewing and comments! TMG
DHolman ( ) posted Sun, 23 May 2004 at 12:21 AM
Excellent shots. Great shots of the normal stuff and super attention to the small detail shots. I'm planning on hitting at least one of the air shows this year and I gotta catch the Blue Angels again. -=>Donald
TMGraphics ( ) posted Sun, 23 May 2004 at 7:16 AM
Thanks Donald. Yeah, the Golden Knights and the Thunderbirds were great! They even had a rare P2 Bomber flying there. I did not get any real good shots of it flying though, this is the best I could get. That thing flies fast! TMG
AntoniaTiger ( ) posted Sun, 23 May 2004 at 7:50 AM
Your pics of the aircraft in flight show up two of the common problems. 1: A high shutter speed, maybe needed with a long lens, freezes the prop. 2: Exposure coming out correct for the sky, with the plane effectively back-lit. It's frustrating. You maybe need a couple of stops over-exposure, and that will burn out the sky, even with a polarising filter. And then you can't rely on standard photoprinting, which will try to compensate. This sort of picture is really quite extreme, and automatic systems will struggle..
TMGraphics ( ) posted Sun, 23 May 2004 at 2:22 PM
I see what you mean, it was really bright out. I adjusted the levels on the flying plane ones, because the plane was dark. Thanks for the tips, gives me some things to look out for in the future! TMG
