Wed, Nov 6, 9:37 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 05 9:36 pm)
Subject: Poser 4 Interface question -- window position
ArtWorker ( ) posted Wed, 26 May 2004 at 10:21 AM · edited Wed, 06 November 2024 at 9:32 AM
This is so stupid, but I'm sure everyone has done it at some point. I was working with Poser 4 this morning when I inadvertantly dragged the Animation Palette window up UNDER the program's submenu list -- you know, the line in which the basic menu commands live: File, Edit, Figure, Object, etc etc. So now the Animation Palette's top line is hidden under the submenu list, and of course that's the only place where you can drag the damn thing around. So now I can't move it, and it's stuck in the upper left corner of my screen. Is there any way I can reposition it? I've tried launching the program every way I can think of, but no soap. I'll take a screenshot of this if I have to, to illustrate my dilemma, but I'm sure everyone knows what I'm talking about.
texmextortilla ( ) posted Wed, 26 May 2004 at 10:35 AM
Try reseting the layout under preferences and setting it to the factory defaults of whatever it is.
odeathoflife ( ) posted Wed, 26 May 2004 at 11:15 AM
then set one of those UI dots and next time yo can just click one of those.
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
geep ( ) posted Wed, 26 May 2004 at 11:23 AM
Hi ArtWorker, Gosh! You are the first person who has ever done this! (ha ha) ;=] And, ... Yup! ... After you fix it, ... (as odeathoflife says) ... set a UI dot so that next time, one mouse click'll fix it. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
lesbentley ( ) posted Wed, 26 May 2004 at 11:56 AM
You might still be able to grab it if you hit the exact right spot under your menu bar. If not try this: With Poser shut down, find the file "Poser.ini" in the path: Poser 4RuntimePREFSPoser.ini Make a backup copy of "Poser.ini". Open the original in a text editor, the line "ANIM_PALETTE_LOC" controles the position of the animatio pallet. Try editing the line using these values: ANIM_PALETTE_LOC 112 364 You may have to experiment with diffrent values depending on your screen resolution, the values above work ok for a resolution of 1024 x 768. Doing it this way you don't have to change all your other settings back to the factory default.
lesbentley ( ) posted Wed, 26 May 2004 at 12:05 PM
Once you get your animatio pallet where you want it set your first UI dot as sugested by odeathoflife, then using a file manager go to; C:Poser 4RuntimeDOTS and write protect 'uiDot_1_.ui2', where "" will be your screen resolution.
ArtWorker ( ) posted Wed, 26 May 2004 at 1:05 PM
Thanks, folks -- muchly appreciated. Resetting to the Factory UI state did the trick -- I'll be more careful in the future. And using the UI dots never occurred to me! D'oh!
ArtWorker ( ) posted Wed, 26 May 2004 at 1:14 PM
By the way, Dr. Geep, your tutes rock. I'm plowing through the animation tute right now. I've been using Poser since v.2 but haven't really ever taken the time to delve into its depths. Last week, however, I scored a freelance gig with ADP to design and animate a character for them in Poser, so I'm on a steep learning curve. Your stuff is really helping me.
geep ( ) posted Wed, 26 May 2004 at 1:58 PM
cheers,
dr geep ... :o]
edited 10/5/2019
