Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=28312
This may be what you are looking for tan line wise? Its by HindsightStudios, and is on my wishlist once I get paid.http://market.renderosity.com/softgood.ez?ViewSoftgood=28312
the link does contain nudity.
I duplicate the body layer(for safety and versatality), and then use the dodge tool with variant setting to remove some of the color but still being able to keep the detail. I have also used the lasso mask and then adjusted the brightness up a little, but then you have use the healing brush on the edges and that is a difficult tool to master. Sorry, can't post the pics here because they are used on for sale characters.
I have done it before, a while ago. The dodge brush is the correct way to go. I made one for Judy, back in the day, and wasn't happy enuf to release it. The tan lines looked good, but the pain was getting it to run across the seams. I wound up fading it almost completely out at the seam, where I couldn't get it to line up. One thing I did, was I put the bikini for Judy on Judy and rendered her off direct line of site from front and back cams, then used the resulting renders to make masks for using the dodge tool. This way, the tan lines and the bikini were the same. (So she didn't have tan lines running out from beneath the bikini when she had it on.) Since V3 is UV'd in completly different way, I think the seams wouldn't be nearly as big an issue, since there are not two "side" seams. I don't think that using a render to make a mask would work there.
A while back Mason also suggested using the blender node with a small transmap to apply the tanlines by using a bikini to make the transmap. Would only work for Poser 5 but it would work. I have a tutorial in the Poser 5 Secrets to create the transmaps for makeup and how to apply it tothe blender node. Try it if you're using P5 and you won't have to create a seperate texture map.
The two textures I know the have tan lines are: Nia for PT girl by Blackhearted. and Destiny for V2 by Predator2K. If you have UTC you can convert them to work on V3. I've converted them both with some success. JV
Software: Daz Studio 4.15, Photoshop CC, Zbrush 2022, Blender 3.3, Silo 2.3, Filter Forge 4. Marvelous Designer 7
Hardware: self built Intel Core i7 8086K, 64GB RAM, RTX 3090 .
Attached Link: Gallery Image: Vista V3
Cernunnos Digital Creations Vista V3 has tan lines. I know you will be pleased with her. http://market.renderosity.com/softgood.ez?ViewSoftgood=25474The best method is to create a new duplicate(s) of the original image on another layer. But first, make a duplicate or copy of your texture image and create a solid but brightly colored bathing suite you desire on its surface. Making sure the suit lines up perfectly and have been tested in Poser on the model (with its morphs) you wish to put the texture on. You now have a template to make any future selections in your imaging program. Now copy and paste it back into your work on a new layer.
Make a selection with the Magic Wand Tool of the suits shape and feather the edges 7 to 10 pixels. Making sure you extend the selection beyond the UV map at the seams so the feathering does not cut back into seam area (you will still want the middle to be solid looking as it goes around the model but feathered toward the outside edges of the suit above and below).If it runs into another portion of the map like the back create another duplicate layer and do the same to it later.
Now invert your selection and delete all the out side image surfaces. Afterwards, erase back to almost the seams you will want to make sure it extends out side 10-15 pixels (depending on your map).
Merge all the suite shaped layers that were created from the original skin texture only. After all most 10 years of using Photoshop daily. The best image adjustment for lighting up large surfaces in my mind is Variations (Image > Adjustments > Variations). It gives a true lighter hue effect that can be controlled at many levels. Others like the doge tool bleaches more than lightens - its good for small areas but hard to control well over larger areas. Brightness and Contrast is better than doge if you are going to print but it seems to gray out fine detail I feel it is really a tool for contrasting purposes only.
Anywaylighten the layer to the desired effect. You now have the option of adjusting the blending options to soften, harden, overlay or what ever.
Message edited on: 05/28/2004 06:20
As mentioned in #3 above HindsightStudios has a fantastic texture product (I purchased yesterday) that has a beautiful body tex "without" tan lines and then 3 versions of tanlines (bikini,G-String bikini, full swim suit). EXCELLANT buy. http://market.renderosity.com/softgood.ez?ViewSoftgood=28312 the link does contain nudity.
I'm searching for a V3 texture with tan lines. Does anybody have a recommendation?
Some pics would be nice. ;)
