Thu, Nov 14, 5:50 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Need women's clothing with breast morphs
divingbuddah ( ) posted Fri, 29 September 2000 at 9:56 AM · edited Wed, 13 November 2024 at 10:58 AM
I need athletic clothing (T-shirt, leotard, sports bra) that conforms and has the same breast morphs as the Poser4 and Victoria models. Where can a get these? What software would I need to make them myself? Painting on texture maps does work well enough (nipples, butt cracks) and I want to amimate so render touch ups are too tedious.
Kevin ( ) posted Fri, 29 September 2000 at 10:06 AM
Magnets. It was the easiest solution I found. You put the clothes on, morph the figure, and the use the magnets on the clothes to make them look right. Then export and import as morph.
dwilmes ( ) posted Tue, 03 October 2000 at 9:42 PM
Put the morphs on the clothing only, then use Conforming Morph controls, so the clothing will automatically adjust to any figure. Then you don't have to re-do it every time you want to use the teeshirt etc on another figure. Nerd has a Conforming Halter Top in the free stuff, for a starter. Doing the morphs is the hard part, making them CM is just a couple of mouse clicks. Dan http://www.neca.com/~dwilmes/cr2edit.html
Rob_Sterling ( ) posted Fri, 13 October 2000 at 11:00 PM
Not sure what a "conforming morph control" is. Could you explain further, dwilmes?
