Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 09 6:38 am)
I dont know if this is what you have in mind, but try exporting the figure to another format, I usually use wavefront obj. Then in the figure tree that comes up only pick the right and left eyes. Hope this helps :)
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
Repeate this process for the right eye. Once you have exported the eyes you can import them back into Poser (un- check all import options), and if you want save them to a props pallet.
If you want you can hide the figures eye by selecting it, then from the Object menu; Properties > Visible (un-check). Then you can parent the new eyes to to the figures head and resave each as a smart prop, or you can use 'Replace Body Part with Prop' from the Object menu.
Sounds lovely dosn't it? I am sure there is a very easy way to do this but I just cannot see it at the moment. All I want to do is split the eyes from Vicki 3 and save them as a seperate object/prop. How do I split them from the main character? Gonzo.
