Mon, Dec 2, 10:22 AM CST
Subject: Vikki Eye Removal
The_Great_Gonzo ( ) posted Sat, 29 May 2004 at 2:59 AM ยท edited Sat, 30 November 2024 at 5:27 AM
Sounds lovely dosn't it? I am sure there is a very easy way to do this but I just cannot see it at the moment. All I want to do is split the eyes from Vicki 3 and save them as a seperate object/prop. How do I split them from the main character? Gonzo.
Fugazi1968 ( ) posted Sat, 29 May 2004 at 3:27 AM
I dont know if this is what you have in mind, but try exporting the figure to another format, I usually use wavefront obj. Then in the figure tree that comes up only pick the right and left eyes. Hope this helps :)
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
lesbentley ( ) posted Sat, 29 May 2004 at 7:09 AM
Load Vicki 3 in Poser. From the menu bar; File > Export > Wavefront OBJ > OK, from the Hierachy Selection box un-x 'UNIVERSE', x 'Left' eye, OK > [name file] Save > from save options check 'As Morph Target (no world transformations)' un-check everything else.
Repeate this process for the right eye. Once you have exported the eyes you can import them back into Poser (un- check all import options), and if you want save them to a props pallet.
If you want you can hide the figures eye by selecting it, then from the Object menu; Properties > Visible (un-check). Then you can parent the new eyes to to the figures head and resave each as a smart prop, or you can use 'Replace Body Part with Prop' from the Object menu.
