Mon, Jan 27, 1:01 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
Subject: why?
shesa ( ) posted Sun, 30 May 2004 at 5:55 PM · edited Mon, 27 January 2025 at 10:50 AM
Does anyone know what is causing this stretchmark effect when I render? It's totally random- sometimes it happens, sometimes not.
Lovely Lady ( ) posted Sun, 30 May 2004 at 6:43 PM
It would help if you mention which version of Poser and if Poser 5 then a screen shot of your render settings.
shesa ( ) posted Sun, 30 May 2004 at 7:11 PM
oh yeah!-P5 - but the render settings dont seem to matter as I've tried different and it still happens off and on w/ any setting, although it seems too be reduced if the render quality is also reduced,but thats not what I want. the quality/image size is the same as i've always used w/out problem, generally shadows off, tex filter on,smmoth poly, filter size 0.02, and max tex size 4000. Also, it's not the tex either have tried lots.
mofolicious ( ) posted Sun, 30 May 2004 at 9:40 PM
This happens to me also all the time and I dont know what it is. I am using P5 sr4 with v3 model. I think smoothing polygons may have something to do with it but I am not sure.
shesa ( ) posted Mon, 31 May 2004 at 12:56 AM
I found the answer over at PP- you neeed to switch off texture filtering in the render settings- the only thing is then your hair may not turn out- so you could do two renders - one w/hair & one w/out-yay!!
maxxxmodelz ( ) posted Mon, 31 May 2004 at 2:33 AM · edited Mon, 31 May 2004 at 2:34 AM
Or you can just reduce the default Minimum Shading Rate (pixels area)in the Firefly settings menu with texture filtering off. A setting of 0.3 or lower whould render just about any hair texture nicely, but you will sacrifice rendertime a bit depending on your CPU. However it should still render faster than rendering two of the same image.
Message edited on: 05/31/2004 02:34
