oh yeah!-P5 - but the render settings dont seem to matter as I've tried different and it still happens off and on w/ any setting, although it seems too be reduced if the render quality is also reduced,but thats not what I want. the quality/image size is the same as i've always used w/out problem, generally shadows off, tex filter on,smmoth poly, filter size 0.02, and max tex size 4000. Also, it's not the tex either have tried lots.
Or you can just reduce the default Minimum Shading Rate (pixels area)in the Firefly settings menu with texture filtering off. A setting of 0.3 or lower whould render just about any hair texture nicely, but you will sacrifice rendertime a bit depending on your CPU. However it should still render faster than rendering two of the same image.
Message edited on: 05/31/2004 02:34
Tools : 3dsmax 2015, Daz Studio 4.6, PoserPro 2012, Blender
v2.74
System: Pentium QuadCore i7, under Win 8, GeForce GTX 780 / 2GB
GPU.
