Photoshop F.A.Q (Last Updated: 2025 Feb 11 11:38 am)
Well,.... probably the easiest way is to use the Glow layer effect. Of course you have to separate out the part that you actually want to glow (put it on it's own layer). Another thing to bear in mind is that sometimes if your having difficulty getting the type of glow you want, it may be easier to do it in pieces, meaning multiple layers. A layer or two for say a tight glow close up to the object itself and then maybe a couple others with wider (and more transparent glows). The glows are transparent so you can build inrensity with multiple layers as well as have a lot more control by affecting the level of transparency/opacity per layer. You can always do it by hand of course. just put the object you want to glow on it's own layer and then create a layer beneath it and airbursh in a custom glow. That can leave you with hard edges on your glowing object up close to it so you may want to address that.
The best investment you can ever make to add to photoshop is Eye Candy. Aside from everything else, there's the gradient glow effect, which you can manipulate in any way you like. I use it often for glow effects. You just can't find a more useful plugin.
Talent is God's gift to you. Using it is your gift to God.
You can select the parts you want to glow (with color range for instance, or with the magic wand), create a new layer and fill it with a lighter color in the same range as the objects. Blur that layer and try different layer blend modes. Duplicate the layer, try other blending modes. It is easy, just experiment.
Attached Link: http://www.cops.nl/Sate.mp3
forgive the suspicious photo.
Message edited on: 06/08/2004 07:40
Attached Link: http://www.renderosity.com/photos/GAL_200406/GalleryImage692872.jpg
Message edited on: 06/13/2004 07:59
I want to be able to make objects look like they are glowing when I am doing the postwork of my renders. How do I get the objects that I am working on to look like that they are glowing? I was trying to work with it earlier, and it was not working too well. I was trying to see about having a character's eyes glow, but I was not able to get the glow to be only in the eyes area. Any ideas?
