ps_pe029 I went through my purchase history at DAZ, found the Victoria 1 Reduced Resolution figure, this is the product code.
There are a lot of things worse than dying, being afraid all the time would be one.
Attached Link: http://secure.daz3d.com/shop.php?op=itemdetails&item=659
She's still there. on the DAZ site just go to the products pull down and click on victoria 3. at the bottom is a link to each of the diffrent versions.My Homepage - Free stuff and Galleries
Your link goes to V2 reduced res. Try the link for V1 reduced res and you get a "no such item" message.
Yup, I have the same thing as wyrwulf. I got VicLoRes when she was a freebie at DAZ ages ago. I thought I'd renamed the file, but since it's the same as wyrwulf's, perhaps that's what it was when I downloaded it. bonni
"When a man gives his opinion, he's a man. When a woman gives her opinion, she's a bitch." - Bette Davis
mateo_sancarlos: Yes, same obj, blMilWomLo.obj. And just in case someone needs to know, V1RR (reduced res, that came with Mimic2 and possibly some magazines) uses blMilWomLoNG.obj. mathman: thanks for this thread. you reminded me that I have all those lo-res people hanging around my folders. I think I'll put them to use :) It's been a while.
Message edited on: 06/05/2004 16:29
This is the reason I always change the name of the file when I download it. Those product codes are useless to me. I always delete the code and replace with something like DAZ_VicLoRes.exe, or something to that effect. The coding they use all looks the same to me, so I'd never find anything I had archived onto CD's. It's saved my sanity time after time. Melanie
Melanie, a better solution is - DON'T change the file name. Instead, put it in a folder with a descriptive name instead. That way, searches will get you hits both ways. I just did a search, found both Vic1LR and Vic2LR in my archives - both May '05. In the same month I also found: JimBurton's freebie SMV Lori Rev2 - even lower res than VicLoRes. And Xena's freebie Parris for Lori. A lot can be done with lores figures, that's for sure! This was also the month that Ken-1 started offering Vicki characters (free). :] Fish
Hi all, Some time ago, I bought the VLR character, and I've been trying to locate her on my backups. Easiest way to do this would be if I knew what the product code was. I posted a search on the DAZ store, got hundreds of hits for Victoria, but couldn't find Victoria 1 Lo Res. If I knew what the product code was, then I could find her. Thanks in advance. regards, Andrew
