Are you talking about boolean operations between primitives ? or between 3D meshes imported into Vue ? While boolean differences between primitives work just fine for me, I always had issues with using 3D meshes, especially when trying to cut holes in a 3D mesh using a Vue primitive. I am not sure it ever worked (at least since the firs trelease of Vue 4).
"trying to cut holes in a 3D mesh using a Vue primitive" That's it. It always used to work for me in Vue normal as far as I can remember since Vue 3. This is the first time I try it in Pro and it doesn't work - but I have not tried it with earlier Pro releases. It leaves in a section of the cut object where it used to end (before the boolean)
Am I the only person whose Boolean Difference doesn't work properly anymore (leaving rubbish) in Vue Pro's latest release?
