Fri, Jan 10, 3:26 AM CST
Subject: About Nine Character Vicky and why you can't get it
Darth_Logice ( ) posted Mon, 16 October 2000 at 2:05 PM ยท edited Thu, 09 January 2025 at 10:57 PM
The host site cancelled my account due to "Adult Content" which I am disputing. Hopefully it will be resolved. If not, I'll serve it off my own computer tonight. But not until I get home from work, in 3.5 hours. (I"m home on lunch right now) -DL
pdblake ( ) posted Mon, 16 October 2000 at 2:25 PM
I had this problem with Crosswinds once, I had written a small goame where a tank had to get across a minefield, naturally they thought that a zip file called Minefield.zip could only contain instruction on how to make things that go bang:) Wonder if they even once considered actually unzipping it to see what was really inside.
Fox-Mulder ( ) posted Mon, 16 October 2000 at 4:02 PM
Hi Darth, I waited in line and finally got Vicky last night, but- When she loads the entire Poser program is BLANK, except for the top menus (never seen anything like it before). So I go to the Hierarchy Editor- and its ALL THERE. But NADA on the screen!!! I have a P-III with 385 MB RAM so that's not the problem. What else could be making Super Vicky become Stealth Vicky?
Darth_Logice ( ) posted Mon, 16 October 2000 at 5:08 PM
lol @ Steath Vicky! Hmmm...Fox, try seeing if there is an rsr in your geometries folder where the blmilwom.obj is or whatever it's called. IF there is an rsr there, delete it and you should be okay. Let me know if that doesn't work. -Darth
Fox-Mulder ( ) posted Mon, 16 October 2000 at 5:58 PM
Darth- Bigger Problems- and the dreaded repeated "Blue Screen of Death". I had figured out that problem one could be the default screen setting for Super Vicky. Reset it to 400 x 400- saved it, reloaded it. Found that by running "Sketch Render" I could get partial display of some of the Poser menus. Leaving Sketch and clicking around, I could get full Poser menus, but any attempts to render or do any other operations caused "bad" crashes. I run a lot of high-end 3D on a fast system so I suspect that something in Super Vicky may be doing this. What? I don't know.
Darth_Logice ( ) posted Mon, 16 October 2000 at 6:40 PM
Fox, ask Jeff_H, he's the poser tech genious. I don't think it's the file, due to other people saying they've played with it and yay, great! So...must be something with your config? The combo or what have you. Can you still open other things? But still ask Jeff_H
wyrwulf ( ) posted Mon, 16 October 2000 at 7:34 PM
I imported the file instead of opening it, and my UI stayed as I have it set. Thanks for the file, Darth. I hope you get things straightened out.
Fox-Mulder ( ) posted Tue, 17 October 2000 at 1:06 AM
I tried both deleting the blmilwom.rsr and importing the file- but still a bad crash when I try to render. I guess I will have to wait until other people report similiar experiences or whatever... I have a lot of Poser DL stuff and have not seen anything go this bonkers before...
