Sun, Jan 12, 11:35 PM CST
Renderosity Forums / Fractals
Welcome to the Fractals Forum
Forum Moderators: Anim8dtoon, msansing
Fractals F.A.Q (Last Updated: 2024 Nov 13 3:03 pm)
Subject: Removing backgrounds with plugins.
gunsan ( ) posted Sun, 30 May 2004 at 4:28 PM · edited Sun, 12 January 2025 at 8:29 PM
Attached Link: http://www.thepluginsite.com/resources/blend/
There are some freware filters for removing background in Apophysis. Use them in PhotoShop, PaintShopPro or oher program David Blends filters. Here I have used one called Transparent Sky-Dark
Whimsical ( ) posted Sun, 30 May 2004 at 8:58 PM
Thanks.. will have to have a nosey at it!! Cheers Whimsical :o) btw.. gorgeous colours in your pic!!
paragon5 ( ) posted Tue, 08 June 2004 at 6:22 PM
Thanks Gunsan, I downloaded them, but I can't seem to get the "transparent dark" to work. Does it need something special to make it work? Maybe it's just me! William
gunsan ( ) posted Tue, 08 June 2004 at 9:09 PM
You must convert the image to a layer first, otherwise it is impossible to make an image transparent.
paragon5 ( ) posted Tue, 08 June 2004 at 10:11 PM
Thanks for the info! Mabe you can tell, but I'm just starting to learn PSP. I have had it for quite a while, just never used it for very much. Now I'm trying to learn all I can. So much to learn and so little time (and brain)! William
gunsan ( ) posted Tue, 08 June 2004 at 10:26 PM
Click on Layers-Properties-OK Then you have the image as a layer, and can use the plugin.
