Wed, Jan 15, 9:42 AM CST
Subject: PP2? or rsr? Poser Model Import Problem...
FearaJinx ( ) posted Sun, 13 June 2004 at 12:05 AM ยท edited Wed, 15 January 2025 at 9:39 AM
I'm trying to import or load a shovel used for poser...I have Vue 4 with upgrades...and it won't work, says there's an error. I've looked through te backroom resources...couldn't find anything about the format PP2 or rsr... I just want a nice spade! LOL! I've tried making my own, but it looks more like a pitch fork wit one prong. LOL! Thanks for your help! Johannah
Djeser ( ) posted Sun, 13 June 2004 at 2:52 AM
Do you have Poser? A pp2 is a Poser prop, and the geometry (the obj) is usually embedded in the prop. If you have Poser, you load the prop, and then either save it as a pz3 scene file and import it to Vue/Vue Pro, or you can export it from Poser as an obj or 3ds. If you don't have Poser, it's not possible to use the pp2, as Vue/Vue Pro don't recognize the format. I"d contact the maker of the prop (if you don't have Poser) and ask them if they have an obj/3ds model of the prop, and if not, if they'd mind if someone else converted it for you. (Has to do with usage and distribution of the prop)
Sgiathalaich
SAMS3D ( ) posted Sun, 13 June 2004 at 4:59 AM
Yes, as said above, save it as a pz3 and import...should be good to go, we have them also for free if you need them let me know, you could import it as an object and apply the texture maps. Sharen
FearaJinx ( ) posted Sun, 13 June 2004 at 8:14 PM
Thank You!!! :o)
SAMS3D ( ) posted Mon, 14 June 2004 at 5:43 AM
FearaJinx, if you want these models, let me know I will set up a download for you. IM me....Sharen
