Do you have Poser? A pp2 is a Poser prop, and the geometry (the obj) is usually embedded in the prop. If you have Poser, you load the prop, and then either save it as a pz3 scene file and import it to Vue/Vue Pro, or you can export it from Poser as an obj or 3ds. If you don't have Poser, it's not possible to use the pp2, as Vue/Vue Pro don't recognize the format. I"d contact the maker of the prop (if you don't have Poser) and ask them if they have an obj/3ds model of the prop, and if not, if they'd mind if someone else converted it for you. (Has to do with usage and distribution of the prop)
I'm trying to import or load a shovel used for poser...I have Vue 4 with upgrades...and it won't work, says there's an error. I've looked through te backroom resources...couldn't find anything about the format PP2 or rsr... I just want a nice spade! LOL! I've tried making my own, but it looks more like a pitch fork wit one prong. LOL! Thanks for your help! Johannah
