Thanks All :-) I used Mimic v1 for the macintosh and used cartoon line mode with one of the original lighting presets that install with poser. i removed all materials and transmaps and assigned simple flat colors to all surfaces with NO highlights. I did run the rendered footage through Adboe After Effects pro to raise the color saturation to emulate the vibrant colors of modern japanese manga. the set up was done in poserpro4 using the DAZ freak and the Dysotopia city block models from rosity free stuff but i did the final 826 frame render from poser5 so i could "work" in other programs while rendering in Mac OSX. got to get to work on some storyboards. thanks for looking :-) -wolf359 founding member of "the twelve animators"-
I do have a Divx5 codec encoder for quicktime
but so far i have had no success creating Divx movies
that my PC bretheren can view so i play it "safe'
and use WMV or mpeg when i can get mpegs down to a reasonable size.
-wolf359 Founding member of "the twelve animators-
Message edited on: 06/16/2004 18:05
Attached Link: 37 second test
HI all, it looks like I may Finally be starting on a new Movie project . and ive decide to animate it and render completely out of poser5 in the cell shaded style. this will mean fast render times and very fast set ups here is a small 37 second "proof of concept" that I rendered last nightMany of you will recognize the audio :-)
later
-wolf359
Founding member of"the twelve animators"-
My website
