Thu, Jan 9, 6:44 AM CST
Subject: Poser 5 cloth room problems
atilla39 ( ) posted Sun, 20 June 2004 at 6:13 PM ยท edited Thu, 09 January 2025 at 6:32 AM
I'm having problems in the cloth room. I get everything set up. I click on calculate simulation. My program freezes up. It doesn't freeze at the same spot every time. Sometimes it goes throuh the draping phase and then freezes. But 90% for the time it freezes on frames 5 through 8. Does anyone know a solution to this problem. I'm running a 2.16 ghz processor with 1 gig of ram.
ynsaen ( ) posted Sun, 20 June 2004 at 6:26 PM
Not enough information. Is the object composed of single sided polys? Is it one that comes with P5 or a custom one? What settings do you have for the simulation? What is it colliding against? processor and ram information is actually extraneous. must have more data -- need data. Data good. Data = Knowledge. Knoweldge = Power. Power = world domination. World domination = um, well, something...
atilla39 ( ) posted Sun, 20 June 2004 at 6:37 PM
I'm using svdl dynamic clothing frames set at 30 draping set at 10 frames collide against figure 1 ignore head collision checked I'm new to poser 5 and trying to learn it. So I don't know that much about it.
randym77 ( ) posted Sun, 20 June 2004 at 7:14 PM
Have you seen the cloth room tutorials at PoserFashion.net? There are instructions on how to use dynamic clothing with the free dynamic dresses in their Poser 5 section. Most dynamic clothing is set up so that it "fits" if your figure is zeroed. If you start with a figure that's not in the zeroed pose, or one that has been morphed from the default, the clothing may intersect the figure (even a tiny bit, where you can't see it). That may cause the problem you describe.
