Are you using P5 and a main figure that uses injection poses.
I've run into problems before where FBMs (Full Body Morphs) that were injected would keep the same FBMs on other figures from working at all (this was with Doger's Aeon girls).
I edited the injection poses and the CR2s for the clothes to get it to work the way I wanted, which was to have the clothes be super conforming.
However, loading a null into the scene first may be enough to stop the main figure from jamming the FBMs of the clothes.
Also naming the FBM something different in The Tailor should work as well
Chris Cox
Message edited on: 06/29/2004 10:43
I think the Tailor works by finding vertices that will interact with the cloth vertices when the morph is applied(Just guessing here), because the v3 catsuit is figure hugging the Tailor may well work, but probably not as well as a Morph loaded V3 would.
As for the queue, I think your supposed to transfer 1 set of full body morphs at a time.
Message edited on: 06/29/2004 15:15
It sounds like you're queuing up the morphs but then only telling the tailor to add the morph you've got currently selected. What command, from which menu are you using to tell the Tailor to transfer the morphs? When I queue things up, I go to the (this is from memory, so I may get the names wrong) "Create Morphs In Dress" option in the "Morphs" menu. That always gets all the queued morphs over (after a decent amount of time). Hope this helps, Unzipped
I have modeled a top. It fits and conforms perfectly. I added some morphs to it in tailor. Buxom, Pinup and voluptuous. When i conform it to the character there is no change in the new top. Even though the dials are in the top they don;t make it any bigger. Any help would be appreciated. cheerio lululee
