The texture map is clearly only assigned to a selected numbers of polys. How to solve this in C4D, tell you I could. But Poser not yet. I would remove the hair altogether, try another one of Koz' wigs and if that works, I'd try this one again at standard settings. The mat file may be corrupt, or simply badly loaded. Just guesses.
I have tried prudent planning long enough. From now I'll be mad. (Rumi)
Attached Link: http://www.digitalbabes2.com/dload/texturefiltering.html
This link will tell you what you need to know :) This one is also useful to have in mind: http://www.digitalbabes2.com/dload/P5notice.htmlthou and I, my friend, can, in the most flunkey world, make, each of us, one non-flunkey, one hero, if we like: that will be two heroes to begin with. (Carlyle)
Attached Link: http://www.oddditty.biz/Files/5Things.rtf
Morst specifically, what you are running into is the single sided polygon problem. P5 doesn't like rendering the backside of single sided polygons. The links above describe what's also about to be described here: 1 - turn off texture filtering in your rendering options. It's purpose is to reduce moire. 2 - add a slight amount of displacement to the hair (and be sure to set your render settings accordingly). This file contains some information on render settings that might be of use.thou and I, my friend, can, in the most flunkey world, make, each of us, one non-flunkey, one hero, if we like: that will be two heroes to begin with. (Carlyle)
Attached Link: http://www.keindesign.de/stefan/poser/firefaq.html#2
From the looks of it, it's the displacement trick that should solve it.Attached Link: http://http://www.renderosity.com/viewed.ez?galleryid=705587&Start=1&Sectionid=1&filter_genre_id=0&
Thank you! Thank you! Thank you! CommanderCarrot, it is by Koz. He has a lot of great looking hair and its free! Here's the web addy: http://digitalbabes2.com/My Store My Free Stuff My Site
Oops! The addy didn't take... lol http://www.renderosity.com/viewed.ez?galleryid=705587&Start=1&Sectionid=1&filter_genre_id=0&WhatsNew=Yes
