would anyone think about buying it when its finished, and what sort of price should i put it up for, thanks for your great suggestions!
Its not an existing car......this is a concept based around a bruttus 7-xr, this is not the same, it is a concept!
so...........would anyone buy it, if the price did not matter, be honest......lol!!!
I'm wondering of those 'imperfections' around the headlights could be the lines for the glass shields....just a thought....
Yes thats where the glass will go, i will change the front end as soon as possible with the mesh, I have nearly finished testureing it now!
I just figured you would apply a trans map to the grille areas.
Like tjohn said. Most of the time those grilles are done by texturing rather than modeled in the mesh. So it's likely there's a trans-map for those parts that appear solid in this clay-style render. It saves on a lot of polys. (And when I say a lot, I mean A LOT. Especially if it's smoothed. Anyone else ever try modeling the grille mesh besides me?) Looks good, but the body panels around the lights do need vert tweaking. A bit of a pain, but worth it. Right now it looks like somebody cut the openings with a saber-saw. If you plan on selling this, nitpicks like this count.
hi, i need to reduce the amount of faces to export it as 3ds, does anyone know how? (im useing 3ds max 6) Thanks Phil!!!!!!!
OOOOOOHHHHHHHHHHHHHH SHINY!!!!!! 0-60 in the speed of light? I want one of these.....full size, mind you! With an 8litre engine and twin turbos.......and a blonde.....and a bank account to match!!!!! This is awesome.....!
You couldn't drive this on my road. Too many potholes, you would grind the bottom off it, LOL.
Beyond excellent model, Ardphil.
Message edited on: 07/02/2004 01:31
Im having a lot of trouble converting it from max to 3ds, 3ds max 6 keeps crashing, should i try doing it in safe mode or something?
Im not sure its goining to convert to a .3ds file, what I am doing is using polycruncher in 3ds max 6, but it just crashes, I might need a bit of help getting it into 3ds! If anyone helps and I would be very gratefull! Thanks Phil :D
Check it out!
