Thu, Nov 28, 12:27 AM CST
Subject: XML Error - What's that??? - Poser won't start now :o(
ericwestray ( ) posted Mon, 05 July 2004 at 10:28 PM · edited Thu, 28 November 2024 at 12:22 AM
Hey Everyone,
Just a few minutes ago, when I went to launch Poser 5, I got an XML Error message that read:
"Parse Error: not well-formed at line 8."
As a result, Poser won't open all the way.
How can I fix this problem?
Please help.
Eric
ynsaen ( ) posted Mon, 05 July 2004 at 10:51 PM · edited Mon, 05 July 2004 at 10:52 PM
Line 8 of your Runtimeuiposershell.xml file is bad. Or, at least, that's the most common one. It does that on occasion, and the root hasn't been isolated. Since this is the xml file that allows poser to display the screen, it's sorta important. There was a manual edit, but I don't recall. Only other solution I know of is to install a second copy of Poser 5 to a different location and copy the file over. The line should read: PSDFile name="./runtime/ui/24000_parmDialPrefs.psd" /
Message edited on: 07/05/2004 22:52
TrekkieGrrrl ( ) posted Tue, 06 July 2004 at 12:15 AM
Isn't it caused by an illegal character in a folder name? Have you made any new folders? Installed anything new? Any folders with { or } in? If you remove that folder it may help (If there IS a new folder with odd characters of course)
Fredy ( ) posted Tue, 06 July 2004 at 1:42 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1791044
Check the link to the attached thread - this should solve your problem...
Bobbie_Boucher ( ) posted Tue, 06 July 2004 at 10:36 AM
Attached Link: http://www.curiouslabs.com/
Basically, you need to update Poser 5 to the latest Service Release. This problem was fixed over a year ago.
zarquen ( ) posted Tue, 06 July 2004 at 1:13 PM
You can simply delete all *.xml that exists into /runtime/prefs. You MUST save again your favorite preferred state.
Bobbie_Boucher ( ) posted Tue, 06 July 2004 at 7:52 PM
Um, why not just get the latest Service Pack(s)?!
zarquen ( ) posted Wed, 07 July 2004 at 12:55 PM
56k phone connection...
Bobbie_Boucher ( ) posted Wed, 07 July 2004 at 11:13 PM
You may consider contacting Curious Labs directly to see if they might send the CD for a nominal cost. The point is that there were several Service Packs that fixed problems such as the one you experienced. You need them to get Poser working properly.
