Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Victoria 3 contains over 147,000 Faces and is a very detailed mesh. It can be exported but not as a 3DS file because, as R Hatch explained, 3DS files are limited to 65535 Faces. If you are using 3D Studio Max you can download Habware's OBJ2MAX and MAX2OBJ plugins which will allow 3DS max to import and export OBJ files.
Ok...many thx 4 the replies..the files corrupt no matter what i'm exporting (entire body or just head, arms etc). I'm already using the Habware plugs..but another problem arises when using them....mainly when i import the .OBJ into Max..i convert to editable mesh...but i'm unable too use soft selection in vertex mode to manipulate the mesh....no matter how small an increment i use the entire mesh is always selected.
Michael 3 WAS exporting to 3DS without any problems...but suddenly went t*ts up.
Anyways...i wasn't aware of the export limitations of the 3ds format, and my patience has worn out....enough to reformat and install winxp...lets see what happens ;)
Message edited on: 07/12/2004 18:15
Anyone know why poser suddenly exports trashed 3DS files?? I don't understand why this has just started to happen. Using Michael 3 with morphs ....maybe this has some thing to do with it ? Using poser 5....also tried poser 4...same thing....anyone had experience with this ??
