For the filter, I suggest experimenting with several different ones and seeing which compliments the eye best. For the repeating texture part You will have to increase the scale of the material slightly. If it's on 1.00 now try 1.25. This way it may stretch all the way up without repeating. You can also change the scale of the picture but remember to do this with the bump as well or it'll look strange. I also recommend making sure you have bicubic oversampling checked on both the picture and the bump. You may also wish to change from a world-standard to and object-standard, otherwise it may be difficult to change the texture orientation. You can try changing the mapping coordinates to "faces" on both the texture and the bump. That sometimes helps the tex to lie flatter. MN
