Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 02 9:25 am)
Er.. Usually a bouquet is just placed in the vase I think.. The vase should fit the bouquet and in that case it's not held together by anything but the vase itself. If you want to put something around them you could try using the Poser torus, adjust the "fatness" and Y-scale of it to make a broad, thin ring-like shape, then apply some satin/silk material to it.
Yeah your bouquet looks great! Hard to believe it's the same rose x 12. I answered in the other thread too with some more suggestions :o)
Hello again, Im trying to compile a bouquet of roses. Ive found a very nice long-stemmed freebie and brought in a dozen of em, and spead em out reasonably nice. Problem is they are all No Figure No Actor props. Ive positioned 12 of em, and parented num 2-12 to num 1 so I can select #1 and move the whole bouquet, but when I try to save as a prop, only a single rose is saved. I know I can save this as a .pz3, but is there anyway to save it as a group prop with the parenting of the 11 roses retained to my Props library? Lastly, I need something to bundle these together, that would look like silk maybe? not sure. What the heck are bouquets that arent in vases held together with anyhow? The render in mind is medieval so all I know is it shouldnt be a modern polymer...... anyone know of a prop that sounds vaguely like what im trying to describe? Thank you for reading :) Logan
