Fri, Jan 10, 10:15 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
Subject: A question on weird shadow effect...
dante ( ) posted Sat, 10 July 2004 at 11:19 AM ยท edited Tue, 24 December 2024 at 6:26 PM
Ok, in this pic, Im using just the default lights. Only one casts shadows, with these settings: Shadow - 0,800 Map size - 2048 intensity - 97% The hat of course is set to casting shadows...but as far as I can tell that band of light inside the shadow is made by the band in the hat for some reason not casting shadows, but the hat is a single obj....so, whats causing that weird band of light?? Thanks in advance
dante ( ) posted Sat, 10 July 2004 at 11:23 AM
Forgot to attach the pic, sorry
dante ( ) posted Sat, 10 July 2004 at 11:25 AM
Well, on further examination, it looks the shadows dont start exactly where they should...btw, this is poser 4.03.
taco ( ) posted Sat, 10 July 2004 at 11:44 AM
Not sure. Did you set the shadow camera properly? They show you where the lights are pointing... so you can fit the things you want shadows on into the frame.
Nance ( ) posted Sat, 10 July 2004 at 12:17 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1059682
Similar hat brim problem & shadowcam adjustment addressed in thread linked above. ![Message1060906.JPG](http://www.renderosity.com/photos/MSG/Message1060906.JPG)
taco ( ) posted Sat, 10 July 2004 at 12:25 PM
Thanx, Nance, for showing this clearly + the link. You were the one who alerted me to the way to solve this prob:-D thanx again... hope it helps dante!
dante ( ) posted Sat, 10 July 2004 at 1:06 PM
Hey guys...thanks a lot really... Cheers
catlin_mc ( ) posted Sat, 10 July 2004 at 8:12 PM
I had this very problem recently with a hat too, but I'm using the P4 renderer in P5 sr4.1. Am I having the same problem and will the fix work in P5 too? If it does I'll be more than happy 'cos this has been driving me nuts. Thank you 8) Catlin
stewer ( ) posted Sun, 11 July 2004 at 7:33 AM
Decreasing the shadow bias can help too.
