gmadone, in theory your shader could work, it depends on how the texture map is laid out. On my map there is actually a lot of black below the gradient., and in the case that you would like the sleeves to flare it would be harder as they are in an angle at that map. I like your node btw, math is greek to me L but I so love the Material room. I'm sure it would be even more fun if I knew what I was doing GG
WOW, gmadone! I have no idea how you did this, but you did! Great, I'm going to snatch your pics for later use :o)
Oooooooooooh that turned out gorgeous, Ronstuff!! Uhm... can I have a copy of that displacement map? :o)
You're absolutely right, AntoniaTiger, - I was referring to an image MAP that is nothing more than a top-to-bottom gradient as shown in Post #2 - those can be generated in P5 quite easily, but of course neither takes into consideration the actual mapping of the object. UV Mapping has a lot to do with the effectiveness of the displacement, and for things like figures and clothing it is probably easier and better to paint the gradients on a body template so that the orientation can be matched to the mapping. ernyoka1 - thanks - I've still to finish the base, but you will get a copy as soon as it is done :-)
