Fri, Feb 14, 12:03 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Carrara Free Stuff here.
Subject: Copy/Paste Object with bones
Lovemends ( ) posted Sat, 10 July 2004 at 3:32 PM · edited Fri, 14 February 2025 at 12:00 AM
It seem that I can't copy and paste object with bones. I hope it is not the way it is. I have tons of object I need to duplicate.
bluetone ( ) posted Sun, 11 July 2004 at 9:28 PM
It is. hopefully Carrara 4 will correct this!
GWeb ( ) posted Sun, 11 July 2004 at 11:22 PM
Carrara 4? No way Joe!
brainmuffin ( ) posted Sun, 11 July 2004 at 11:26 PM
Try saving the boned object alone as a .car file, then import it into a new file as many times as you need it.... I don't know for sure if it'll work, just a hunch....
ominousplay ( ) posted Mon, 12 July 2004 at 1:33 AM
I had to do just what brainmuffin suggested, minus lights and camera, just the model with bones and I was able to add as many as I wanted. I just deleted the light and camera once I imported the .car file into my scene. I'd also like to see the feature in Carrara 4. I'd also like to be able to work with the trees without waiting forever. Has anyone made trees without leaves, then used a material over spheres? R.
Never Give Up!
falconperigot ( ) posted Mon, 12 July 2004 at 10:50 AM
The low poly version of trees would work very well, using trans maps to produce the leaves. Probably better to use half spheres or dished grids. Brian Taylor uses this technique very effectively in Rustboy.
