Tue, Dec 24, 6:16 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Vertex Boolean subtraction
Pinklet ( ) posted Thu, 15 July 2004 at 4:23 PM · edited Mon, 23 December 2024 at 7:01 PM
O.K. I select both shapes, I Otion/Alt click on one of the the points of the shape that I want to subtract...
But my problem is that the point never turns yellow, so the subtraction never takes place. Im I missing something?
Thanks to anybody with an answer. Yes I am running Carrara 3 with the latest patches.
Kixum ( ) posted Thu, 15 July 2004 at 9:27 PM
I'm not sure I understand your question. Can you post a screen capture? -Kix
-Kix
Animoottori ( ) posted Fri, 16 July 2004 at 12:47 AM
Are you using select-tool or move-tool while option/alt clicking? You must use alt/option move-tool (probably almost any other than selection-tool will do) to select the yellow point. I didn't manage to do it either when I was starting to work with Carrara. -Hannu Kulju
falconperigot ( ) posted Fri, 16 July 2004 at 2:51 AM · edited Fri, 16 July 2004 at 2:51 AM
The keystroke is Ctrl+Alt click (Windows) or Command+Option click (Mac) - if Option is the equivalent Mac key to Alt.
Message edited on: 07/16/2004 02:51
Pinklet ( ) posted Fri, 16 July 2004 at 9:56 AM
My bad. I misread the dialog box that came up. I was not holding down the Command key, only the Option. It works. I am dumb butt. Thanks everyone.
