Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 02 9:25 am)
If she's saved as a cr2 then you might be able to use Morph Manager to transfer her morphs (with their values still set) over to a fresh cr2. You can also try using your saved cr2 to create a MOR or INJ pose and use that to apply the settings to a new figure. Or do it the painfully hard way and read through the cr2 by hand to get the values. Good Luck!
Well I can't put my figure on any one thing that would casue that kind of error. Now I've gotten all sorts of weird errors caused by crashing during a save or render, and I've even had some random errors casued by objects poser didn't like that day. (really ..Monday it was fine, I use the prop in a different pic Tuesday .. and it wouldn't render. Diva program) Generally poser likes to eat its own files, so I'm not terribly surprised when I have a pz3 or cr2 go south on me. if the pz3 is bad I try extracting the cr2. if the cr2 went south, then you get to recreate the figure. Save early, save multiple steps and test regularly until you either find or eliminate all probable causes. Then if you find out the error was caused by something you did ... NEVER do that again :)
"1st was "sharing violation" when I tried to delete a corrupted PZ3" I got this all day yesterday. I had opened a PZ3 in poser to see what it was and determined that It was an old enough version of a render to delete to save space, and when I attempted to, It would not allow deletion until poser had been closed completely. Evidently even when you hit the File>Open or File>New option, poser just doesnt completely let go of the last pz3 it was reading from. This happened to me on PPP. Good Luck, Id love to see the char your trying to recover Logan
There was a problem in saving. Save could not be completed... When I render, saved renders are gone, too. Checked this 10 times (p4 drafts) in tiff. Same proceedure..no changes..no new downloads. I'm stuck. I suspect a missing morph but I hate to guess. Anyone ever deal with this beauty? Don't want to redu this...she has a gozzilian morphs. ,prozac
