PC or Mac? On a Mac, it's easy, just command-I and reset the memory allocation, then restart. On a PC, depends on which version of Windows you have.
How much memory do you have? You can't assign more RAM to any application in Windows but you can increase the virtual RAM/Page File size. Instructions on how to do this can be found at CL's site.
Low memory is a generic error message in Poser. What version of Poser are you using and what characters are causing the problem? Make sure you have the latest update for Poser or with Poser4 and lower, the Geometries RSR is probably corrupt and must be deleted. Poser will make another when you load the character.
I agree with everything that's been said here. I'd only add that there is an additional update that CL has regarding memory issues...think they call it Poser Pro Pack Memory Updater and it's for Poser Pro Pack users with greater than 1GB of total memory (RAM + virtual memory = more than 1 GB.) to run normally. I use XP also and I've had the problem when I'd do a "new window" render and it fixes the problem immediately. just my two cents jen
Check out my full gallery at Cliff-Dweller Artworks
What I meant was that it takes longer to help you if we need to get all the information before we can give the answer. For example, if you told us you have 128MB of RAM, we could say you indeed don't have enough memory. If you told us you have 512MB of RAM, then you probably have enough memory. In that case, Poser is probably telling you it can't find a geometry file. If Poser can't find a geometry file, it complains about that first, then it says you don't have enough memory. (Which is actually a lie.)
Message edited on: 07/18/2004 09:23
You can also download something that takes memory away from things that really doesn't need it and put it to Poser. Its wonderful. Its at memturbo.com
My Store My Free Stuff My Site
When I try add certain new figures to my doc, I keep getting a "warning message" that my memory is low. What can I do about that, or how can I add more memory to Poser? It's driving me crazy
