Thu, Feb 6, 3:41 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Feb 05 8:15 pm)
Subject: Renders, washed out
Jcleaver ( ) posted Fri, 09 July 2004 at 6:27 PM · edited Tue, 07 January 2025 at 12:51 PM
I am trying DAZ|Studio, but every render appears washed out. Not very appealing at all. I have the quality slider all the way to the right for most quality, but no change. Is there other settings for the 3DDelight renderer that I'm not seeing? Or is this normal?
DaveH02 ( ) posted Wed, 21 July 2004 at 7:53 PM
Mostlikely, you have all your materials still set to a plastic lighting model. What you need to do is go to your surfaces tab, then click on sideways triangle in upper right and click on show surface list. This will list all the material zones in all of your figures. Doing this will allow you to select multiple material zones at once. Once you have what you want to fix selected, click on the advanced tab on the right side of the surfaces window, and scroll down to the bottom. The lighting model selectoins are a drop down menu, and you can select something else to set how the model reflects light. You can also tweak the glossiness settings from the Advanced menu, it is close the top.
Jcleaver ( ) posted Wed, 21 July 2004 at 8:44 PM
Thanks. That did help some. I think maybe I'm expecting too much though. I do almost all renders now with other apps, mainly Carrara. It appears to be much better than D|S, Poser Bryce, or even Vue. Although, I really like Vue, Vue's OpenGL doesn't like me!
DaveH02 ( ) posted Wed, 21 July 2004 at 10:02 PM
Studio's Lighting is not as... weak (?) as Poser's lighting. The settings do not transfer over very well, and they always need to be tweaked. The more Poser lights in a D|S scene, the brighter the scene will be. If you are using some of the DAZ global lighting, you will need to kill off some of the ambient lights to get the same effect. I have yet to figure out what the magic number is for reducing the percentage of the Poser lights in Studio.
Jcleaver ( ) posted Thu, 22 July 2004 at 8:24 AM
My tests with D|Studio has always been with the supplied Egyptian scene. I figured that it should have been tweaked already to show Studio off in it's best light. (bad pun unfortunately intended). Apparently that is not the case.
