Thu, Jan 9, 1:02 PM CST
Subject: using poser on two pc's
kedo1981 ( ) posted Fri, 23 July 2004 at 8:50 AM · edited Thu, 09 January 2025 at 1:58 AM
My home computer and my work computer and never the two shall meet; but I need to user P5 on both. The home pc reg'ed just fine but having trouble with the work system's registering. Pretty sure this is legit useage of poser 5, since I am only only using each sys at time
neilp ( ) posted Fri, 23 July 2004 at 9:28 AM
I reckon you will have to contact Curious labs for this one.
HullBreach ( ) posted Fri, 23 July 2004 at 10:29 AM
The license is a "like a book" type so technically as long as you don't use both simultaneously, its legal. Please note IANAL (I am not a Lawyer)
Berserga ( ) posted Fri, 23 July 2004 at 11:13 AM
Why are you registering it again? Just install the most recent patch it removed the copy protection junk. and IMO, this falls under fair use.
ynsaen ( ) posted Fri, 23 July 2004 at 11:26 AM
It doesn't fall under fair use, but, as noted, it is covered under the EULA -- you can do this. Software is never covered under fair use in this manner.
Aeneas ( ) posted Fri, 23 July 2004 at 1:30 PM
Besides: P5sp4.1 will check out if there is a network, and if so, if there is a P5 install on any ther linked puter. Which is fair also.
I have tried prudent planning long enough. From now I'll be mad. (Rumi)
Tyger_purr ( ) posted Fri, 23 July 2004 at 3:21 PM · edited Fri, 23 July 2004 at 3:22 PM
yup, i had a scene rendering on one machine and linked up my laptop so i could sincronize my runtimes. I forgot i put my laptop into hibrination with poser up. when they saw each other poser on the laptop closed (allowing me to save first). I assume it closed because the other was rendering at the time.
Later to test the theory, i set them both to rendering and linked them. the one that finished rendering first closed down (with the option to save the image and pz3 first)
Message edited on: 07/23/2004 15:22
My Homepage - Free stuff and Galleries
