Wed, Feb 5, 2:29 AM CST
Subject: Z-toon Python script error message
Cyhiraeth ( ) posted Fri, 23 July 2004 at 11:54 PM · edited Mon, 27 January 2025 at 1:31 PM
I was trying to make a z-toon in Poser and use Ockham's Z-flatten python script, but I got this error message that said "AttributeError: ParentActor". Does anyone know what this means? I'm using P4 Pro Pack.
TrekkieGrrrl ( ) posted Sat, 24 July 2004 at 3:32 AM
The only times I've got an error with the z-fletten is when I had selected another bank of props with PBooost, so that the poser ball wasn't available... but I can't remember if it was that error I got at that time. Still if you DO use PBooost, it may be a reason :o)
Cyhiraeth ( ) posted Sat, 24 July 2004 at 3:41 AM
I'm not using P-Boost, but I have moved a lot of stuff around, so I guess I better check and see if the ball is still there and accessable ;-), thanks.
ockham ( ) posted Sat, 24 July 2004 at 9:05 AM
Very often, this "attribute error" means that you have an earlier version of ProPack. Look at "Help:About Poser" on your main menu, and see if you have 4.2.1.179 in the version number. If not, you need to get the last Propack service release from CL. (The earlier version was just plain buggy in the Python department.)
My python page
My ShareCG freebies
ockham ( ) posted Sat, 24 July 2004 at 10:20 AM
It looks like I did change the script itself at some point, because the ParentActor thing was making trouble for some people. The change was made 4/15/04. If you're using a version of the script before that, download again and get the newer one.
My python page
My ShareCG freebies
