Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Check that Transparency and Transparency edge are both 100%. If it's not that, then I really don't know.
I second SamTherapy's suggestion. I've seen this before with other hair, though, but only in C4D. One other idea is to check the map size on your shadow maps. If it's low (and by looking at the rest of your pic, it doesn't seem low) you'll get weird effects through transparency (looks like dirt/banding). Finally, I'm not familiar with the model itself, but if it's like other hair there will be a material zone called "skull cap" or something. Not only do you need to check that it's transparency is 100%, but you also have to make sure no color has been applied to the skull cap material, other than white. Please somebody speak up if I'm totally off base! Hope this helps, Jack
I think it's a shadow. I tried to reproduce the effect, and couldn't do it with transparency settings. (You get a sharp line, much farther up, not bands across the whole forehead.)
However, moving a light so that it was overhead produced lines. Turn off "cast shadows," and it's gone.
Try increasing the size of your shadow map on the light that's overhead. I tried four times the default size, and the lines vanished. Smaller might work, though - didn't try it.
Message edited on: 07/26/2004 22:06
Thanks, randym77. I'll check that out. **** a few renders later**** T'was the shadows. Thank you randym77 and all who posted.
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD
space
space
Any suggestions?
