Mon, Feb 10, 10:29 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 10 9:40 am)
Subject: Is there a way to input .midi or .wave sounds ?
Methastopholis ( ) posted Tue, 27 July 2004 at 8:08 AM ยท edited Mon, 10 February 2025 at 10:17 AM
yea i was wondering if there is a way. to input background sounds from a .midi keyboard or use a virtual keyboard. Into poser 5 in real time. add sound effect useing keyboard midi piano .mid keyboard .etc so i can add sound effect a whole lot easier. some way to inport sounds from virtual piano (keyboard) ?? Like some way to link the inport sound in poser 5 to my virtual piano (keyboard)? so that when i keystroke it will inport sound ? I know it an odd question . But it be sweet if that option was avaible.
neilp ( ) posted Tue, 27 July 2004 at 8:51 AM
The only sound that I know Poser will deal with is a WAV file that you can load when doing animations although there was a freebie Calliope with played a midi file through a python script. Search the freebies for Calliope.
ockham ( ) posted Tue, 27 July 2004 at 9:27 AM
Look at the files in ockhamsbungalow.com/MIDI and you'll see several different MIDI uses. But my MIDI stuff is all based on reading .MID files to control a model instrument inside Poser. This is sort of backwards from what you're proposing. It's an interesting idea. How exactly would you want it to work? Set Poser to a frame, then hit a key to insert a sound beginning at that frame?
My python page
My ShareCG freebies
Methastopholis ( ) posted Tue, 27 July 2004 at 10:22 AM
yea thats what i been playing around with Calliope and the telgraph. Ockham you say you have a midi package ill check that out. Yea pretty much (It's an interesting idea. How exactly
a sound beginning at that frame? ) but also maybe have a few settings for sounds like : words per minute setting like FPS or tempo speed. also be able to create mutiple sound layer effect per frame with option of volume on each individual sound layer created. basicly you'll have your animation timeline . Then have lets say 3 seperate sound effects timeline. Then you have your normal background sound input. Also Mimic .
I know im dreaming but it would be pretty sweet.
Ockham im having isues with telgraph .py it say im missing
text file for it i made one but it doesnt see it ? what do i do ?? this is what it says::
(Traceback (most recent call last):
File "", line 631, in ?
File "", line 466, in RunMorse
File "", line 448, in ReadFile
Text file not found!
Thanks for the response people
ockham ( ) posted Tue, 27 July 2004 at 10:29 AM
I'm working on a large sound-effects script. It won't be free, but it already does a lot of what you're mentioning. I'll see if there's a way to include direct MIDI input with this script. ------- On the telegraph: The text file needs to be in the same folder with Poser.exe. Then you can just put its name (no file-path) in the blank. (I wrote that script a long time ago. Since then, I've figured out better ways to pick up a file!)
My python page
My ShareCG freebies
