Thu, Jan 9, 11:25 PM CST
Subject: Ready to pull my hair out (The models hair is already screwed)
HullBreach ( ) posted Tue, 27 July 2004 at 12:00 AM ยท edited Thu, 09 January 2025 at 3:14 PM
Ok, I have figured out most of the pitfalls and problems with the hair room except one: When I calculate the simulation it works beutifully right up untill the last frame, when the hair, for lack of a better way of putting it, pops back up. Its almost like it ignores the second half of the simulation frames. Any advice for me?
GladysClump ( ) posted Tue, 27 July 2004 at 2:36 PM
Since no one else has answered this...I'll take a stab at it, feel free to correct me if you know otherwise. I'm not positive and I've only used the hair room a few times, but if you're not animating, I don't believe you need to run the simulation. I think you would only use it if you wanted to add wind or movement. Personally, I don't use it. But if you do use it, then you can, play it back and use the frame that you like the best...like with the materials room.
HullBreach ( ) posted Tue, 27 July 2004 at 4:22 PM
Thanks! It worked great, all I had to do was regress a few frames, and I had exactly the output I wanted!
