Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 1:08 pm)
Since no one else has answered this...I'll take a stab at it, feel free to correct me if you know otherwise. I'm not positive and I've only used the hair room a few times, but if you're not animating, I don't believe you need to run the simulation. I think you would only use it if you wanted to add wind or movement. Personally, I don't use it. But if you do use it, then you can, play it back and use the frame that you like the best...like with the materials room.
Ok, I have figured out most of the pitfalls and problems with the hair room except one: When I calculate the simulation it works beutifully right up untill the last frame, when the hair, for lack of a better way of putting it, pops back up. Its almost like it ignores the second half of the simulation frames. Any advice for me?
