Well, it depends on what you want exactly. If you only need a prop (head and eyes), just File -> EXPORT as an .OBJ-File and re-import it as a prop. You can do this also with the grouping tool: select the head then use the grouping tool "new group / add all / create prop". Then save the prop into your props-library. Making a fully poseable fihure, like, a talking head, is more difficult. You can use the above mentioned prop and copy the head morphs with a tool named Morph Manager (do a search - it's in the freebie section). Willy
If you are using Pro Pack of P5, you can probably do this using the setup room. Export the head with eyes as follows, when the gray export box opens, uncheck all boxes, and then check Include existing groups in polygon group - this will keep the internal names for the body parts intact. Import the object back into Poser, go into the setup room, load the cr2 for the figure as your bones - if you have morphs for the head already loaded in the cr2, then they should work okay on the head. Return to pose room and you should have just the head, with no body. Save to library - be aware that Poser will create a new geometry obj for the figure and put it in the same folder where you save the figure. So, if you save the file as Head. They Poser will make a Head.obj and will look for it in this folder next time it calls up the figure. If you want to clean up your cr2, you can open it in morphmanager and delete the morphs for the body parts not used. If you do not have P5 or PP, you can do step one to export the head and eyes as an object, with the interenal groups. Put this in a folder - make a geometry folder for it if you like. Then take a copy of a cr2 for the figure, and change the call path so that it looks for your object, and save the file with a new name so as not to overwrite the original. The call path is in two places near the top of the cr2 and looks like this: figureResFile :Runtime:Geometries:DAZPeople:blMilWom_v3.obj (this example is for V3, the geometry folder and object name may differ for whatever figure cr2 you are using. Just change the path so that it points to the location where you have the head.obj you made saved. Again, this line appears in two places, so be sure and change both). Rob
Oh, using a text editor there is another way you can do this, similar to hiding the figure, only what you are doing is hacking the cr2 so that only the head and eyes load. You are still calling the original object.
To do this make a copy of the cr2, I will use V3 as my example.
I change the name of the cr2 to V3head.cr2 so as not to overwrite my original.
In a text editor, near the top, you will see a list of the body parts, that will look something like this:
actor hip:1
storageOffset 0 0 0
geomHandlerGeom 13 hip
actor abdomen:1
storageOffset 0 0 0
geomHandlerGeom 13 abdomen
etc. for each body part
Delete the following lines:
storageOffset 0 0 0
geomHandlerGeom 13 "name of body part here"
For all body parts - except the head and eyes - it will look something like this for all the empty body parts
actor hip:1
actor abdomen:1
Again, do not delete the lines for the head and eyes. This tells Poser to load these parts of the mesh when loading the figure.
Save the file.
When you load it in Poser, only the head with the eyes will load. Again, you can use morphmanager to delete any unneeded morphs from the cr2.
Message edited on: 07/28/2004 13:10
If you export the head + eyes as an object and re-import that object as a prop, the head's morphs won't work, because adding the eyes adds more vertexes and that stops those morphs from working. You will have to export each eye as a separate object and turn each eye into a prop and parent it to the head.
i need to know how to get the head off a figure. do i need a text editor or is there a way to do it in poser...see i don't want the characters body, just the head. instead of shutting off the visability for everything there must be a way to detach it as v2 has in the additional figure liberary.if any one knows please help, i need it for a school project ( i swear i'm not using it for personal gain) just a disecting assignment. no grade. like i said any help would be greatly appreciated.
