Mon, Feb 10, 8:56 AM CST
Subject: 1,53GB DDR /128MB GForceFX :Bad perfomance with PProPack!
softcris ( ) posted Tue, 27 July 2004 at 4:44 AM · edited Mon, 10 February 2025 at 8:41 AM
I got a problem that until today could not find out a solution. Having 1,5Gb Ram I did install the Memory Pacht for Poser. After that for no reason at all every time I open PoserProPack 4.0.2 it lowers the graphic card Colour Quality to 8-bits(when default is 32-bits)and I have to set back to 32-bits while Poser is open to operate in 32-bits. The renderings it makes shows me in some kind of noise 8-bits! Final results when I open the render in other software is normal but not when showing me in PPP. Can't fix it just if I take off one stick Ram and lowers to 1GB the memory! Any smart solution here here? Please tell me!
"'you shut up!  or I'll bring democracy to your country! "
Cris Galvão aka Softcris  - www.crisgalvao.com
(or softcris, SoftCris)
Rendering since 1997 and
at Renderosity since 1999.
OS Win 8.1     64 bit
Philywebrider ( ) posted Tue, 27 July 2004 at 4:59 AM
TrekkieGrrrl ( ) posted Tue, 27 July 2004 at 6:08 AM
The memorypatch may not be enough. From your version # it seems you haven't installed SP3 for Pro Pack. Try it and see if it helps :o) You can get the windowsversion HERE (9.95Mb)
Dale B ( ) posted Tue, 27 July 2004 at 7:31 AM
Also, what OS are you running?
Sarissi ( ) posted Tue, 27 July 2004 at 8:14 AM
Install poser - Install Large Memory Patch - Install Pro Pack. In that order. I am running Windows 2000 Pro + SP4, 1.5 GB DDR333, and an nVidia GeForce FX 5200 128 MB, 8X AGP. I have antialiasing set to 4X (for now), cause of Daz Studio. I have NO problems with any of the Poser programs (P4, PP, P5), Carrara Studio 3, or any other CGI app.
Lovely Lady ( ) posted Wed, 28 July 2004 at 5:10 PM
Poser does not use any of the nVidia antialias settings. Make just a profile with application controlled antialias and see if that helps. I don't have Pro Pack, but have no problems running P4 or P5. I have an nVidia GeForce 5600 FX with 128MB on Windows 2000 and had 1 GB of ram before one stick of ram tested bad and kept crashing my machine. Waiting for the replacement from the manufacturer. Also, what nVidia driver version are you using. There is a new one out, but I have not installed it as they say, "If it ain't broke, don't fix is". I am still using "5663"
