Carrara F.A.Q (Last Updated: 2025 Jan 11 8:46 pm)
I've had a great deal of difficulty with getting smooth motion of cameras in Carrara. One thing I've done is to create a target object (in fact, I think Carrara has a Target Helper Object built in, now, but I just use a sphere that I move around, then make invisible before render). The target object can be moved, and you can keep your camera pointed at the object; you can still effect banking in the camera and such, but it will stay pointed at the object. It's kind of a wonky solution, but it does help to get rid of those wild movements that happen before keyframes. I'm hoping that they're able to make the animation in the next version of Carrara less bizarre. I'd love to be able to use easy-ease and easy-ease-in and easy-ease-out commands for the tweeners like we see in AfterEffects.
I have an animation where camera's movement is controlled by motion path.
Bank and align is set on for the amount of 10% and there are a few keyframes which determine where camera should be at each moment. The problem is that the camera banks unexpedtly near the keyframes and then returns back to the original banking after a few frames.
The tweeners are set to bezier and within bezier:
Ease In-Out:0 - 100;
Tighten In-Out:33-67%;
Has anyone got an idea how to get the camera bank smoothly all the way?
-Hannu Kulju
Message edited on: 07/26/2004 14:41
