Wed, Feb 19, 2:56 PM CST
Subject: WIP texturing problems
MoonGoat ( ) posted Sun, 01 August 2004 at 4:37 PM · edited Wed, 19 February 2025 at 2:56 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=107&Form.ShowMessage=1870448
In the old thread, Twisted_Symmetry declared that the picture could use "greenery ... like long tentacles of thick growth." Using Bryce 4 to do so is an interesting process, so I ended up with 4 different ideas. I need help with finding the perfect thick growth look.
Here 'tis shown normally.
MoonGoat ( ) posted Sun, 01 August 2004 at 4:38 PM
Now with a mossy rock texture.
And yet another mossy rock texture.
MoonGoat ( ) posted Sun, 01 August 2004 at 4:40 PM
And finally I used the original, duplicated the mountain and enlarged it by .01 bryce units in all dimensions, then set it to a foliage procedural texture. So help me out, what do I do?
Ang25 ( ) posted Sun, 01 August 2004 at 5:09 PM
I like post #2 the first mossy rock texture the best.
Swade ( ) posted Sun, 01 August 2004 at 6:21 PM
Attached Link: http://3dplants.0catch.com/download.html
I like post #2 as well... your first mossy rock much better than the following 2. You can go to the link and download some free vines if you are looking to add some tentacle like growth. They would need to be rescaled of course and have a mat put to them. But that may help you some in what you are trying to achieve.
There are 10 kinds of people: Those who know binary, and those who don't.
A whiner is about as useful as a one-legged man at an arse kicking contest.
TheBryster ( ) posted Sun, 01 August 2004 at 9:07 PM
Did you know you can increase/decrease Bryce units by 0.001 ?
MoonGoat ( ) posted Mon, 02 August 2004 at 12:19 AM
cough bryce 4 cough
TheBryster ( ) posted Mon, 02 August 2004 at 3:13 AM
I take it that you can't in Bryce 4 ?...Doh!
pogmahone ( ) posted Mon, 02 August 2004 at 3:19 AM
I like #2 as well, but to my eyes it'd look a bit more convincing colour-wise if it had a hint of yellow in the green. Sticking some trees inside the mountain and letting just a few branches stick out might work too?
danamo ( ) posted Mon, 02 August 2004 at 5:16 AM
I agree with Pog on the green. Another thing that can help make it more convincing is to add a little noise to the heightmap of your copied terrain. This gives the foliage material a little dimension of its own. Sometimes just moving the copied terrain on the Y a tiny bit gives a better effect.
MoonGoat ( ) posted Mon, 02 August 2004 at 12:46 PM
Whoa nice image. I'll try all these ideas, thanks for the help!
pogmahone ( ) posted Tue, 03 August 2004 at 9:27 AM
I hope you don't mind me making the suggestion that what struck me about your first image was that it might look good if the top (roof) looked as if it was the top of the same rock, and that the intervening space (where the building is) had just been sliced out. And also that it would be pretty easy to do using a lattice to cut out the middle bit. Alternatively, if you wanted to have the top and bottom as two separate bits you could duplicate a terrain, then slice the top off one using the clipping bracket, and the bottom off the other (duh, just realized that's probably exactly what you did!) Anyhoo, here's a quick and dirty render of how it looks using a heavily-noised lattice as the negative.
