Mon, Feb 10, 9:25 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 10 9:07 am)
Subject: Light effects: How do i do THAT?
MINTY1974 ( ) posted Tue, 03 August 2004 at 7:21 PM · edited Sun, 09 February 2025 at 6:49 PM
Greetings all. I have an image in my gallery 'HUNTRESS' which I would like to add a little bit of volumetric lighting (dust particles/light beams etc.) The question is how do I achieve this in poser 4? Are there any freebies out there that anyone knows of? Or any techniques in Poser 4 itself? Cheers in advance. Tony.
xantor ( ) posted Tue, 03 August 2004 at 8:45 PM
Light beams could be faked by making a square or rectangle with a transparency map with the beams drawn on grey and the rest black. If you make the beams grey then they will be partly see-through.
xantor ( ) posted Tue, 03 August 2004 at 8:46 PM
Dust particles could be made with another transparency map on a plane with small dots on it for the floating dust.
JVRenderer ( ) posted Tue, 03 August 2004 at 8:49 PM
There is a tutorial on how to achieve volumetric lighting in Poser 4 as well as Poser 5. You can find them here. Good luck. JV
Software: Daz Studio 4.15,  Photoshop CC, Zbrush 2022, Blender 3.3, Silo 2.3, Filter Forge 4. Marvelous Designer 7
Hardware: self built Intel Core i7 8086K, 64GB RAM,  RTX 3090 .
My Gallery  My Other Gallery
MINTY1974 ( ) posted Tue, 03 August 2004 at 8:53 PM
Cheers JV but for that tutorial you need the Nerd3D fog tool which I do not have :( thanks for helping anyway
Crescent ( ) posted Tue, 03 August 2004 at 10:54 PM
I know there's a few volumetric light props in the Free Stuff area. I found one off-hand; do a search for: Emulated Volumetric Light FX - that one might work for you. (I haven't tried it myself.) Cheers!
Engel47 ( ) posted Wed, 04 August 2004 at 7:44 AM
Minty - in the tutorial that JVRenderer pointed you to it actually says "Load a prop square and scale it to fill the background of your scene. (Or you could use the Nerd3D Backdrop Tool with no texture ;-) ) It also says "There must be something behind the figures for the volume to show up. A prop Square scaled to fill the window will work" I cant find any reference to Nerd3D Fog tool. It looks like a great Tutorial.
geep ( ) posted Wed, 04 August 2004 at 11:03 AM
cheers,
dr geep ... :o]
edited 10/5/2019
