My standard for the Cloth Room is 30 frames. first load your figure, turn off all IK, go to Windows/Joint Editor and click Zero Joints button. Load your dynamic cloth item. Make sure it loads pretty much properly fitting your figure. advance to frame 30 on the animation counter. Apply your pose to your character. Go to the Cloth Room and click 'New Simulation' Enter 15 frame for Draping. Click Clothify and select your dynamic cloth prop. Select collision objects (your figure at a minimum). click Calculate Simulation. When all is done, your figure should be in your pose, the cloth should be covering the figure and look 'natural' and the animation counter should be at frame 30. You can slide the animation counter back and forth and your figure will move from the classic 'daVinci' pose to your selected pose with the cloth item following. If you want a new pose, you will have to run the simulation again, and remember to only apply your pose at frame 30. Hope this helps. Shogakusha
These are good ideas to get started with. Draping time is going to vary, depending on the size of the cloth item and the complexity of the object it is draping against. You will find that adding more frames that 30 for the effects will be more and more appealing. There is both applied gravity and applied intertia; if you have the figure move a distance, there will be a tendency for the cloth to want to 'stay in place' (conservation of momentum). Thicker cloth can take longer to drape, and if your character moves any great amount, you may need to add 30 to 60 frames at the end of the animation to allow things to stop swaying and settle once again. On the other hand, this can lead to some very impressive still renders. By choosing the frame in the animation that has the look you wanted, you can have effects that seem to suggest that serious action is occurring.
Attached Link: http://www.PhilC.net
I use PhilC's tute the one using the halter dress as a sample however you can use any dynamic clothes you want it will work the same look under the tutorial tab on his site I love the cloth roomYou might as well PAY attention, because you can't afford FREE speech
I also like to add a little twist in the figure body to get a nice flow to the clothing. so say your end pose is on frame 15, youmay want to add a 25 deg twist to teh whole body as well. The cloth room is super fun and I found very addicting once you start playing with it.
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
Attached Link: http://www.renderosity.com/freestuff.ez?Topsectionid=1&Form.SortOrder=UserName&Start=299&Sectionid=
Have you tried this? deTriangle, some thing to that name. Anthony Appleyard? Not sure of the name (SP) The link will take you to the last page of utilities, you'll find it there. I make my stuff in Wings, don't need this kind of stuff. Also, not sure, but I think you can change it in Wings too. Tesselate gives the option of Tri or Quad.Attached Link: http://www.poserfashion.net/tutorials.htm
"Not really helpfull" - have we not solved your problem yet, Robo2010? Try Serge Marck's tutorials - they go deeper than you need at the moment, but certainly got me started.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Today, I thought I should give Dynamic cloth room a try. I download a few Dynamic cloth freebie's. Looked at a tutorial, "Do not pose yet"..."Set Parent, to hip" and so on. Then go into cloth Room.."Clothify". So when do I pose the character? In a animation? The outfit is one complete prop, that if I do pose the character, the outfit goes the oposite way. I have to do it all over. I am not into this cloth animation yet. Only to understand the cloth room and Dynamic clothing. Maybe I jumping to far ahead. Any suggestions?
