Interesting effect. Thanks for the tip :o)
What seems to happen with the mat room is that when you first go into it, with a mat pose applied, the node connected to diffuse_color will be called "Color Texture". If you then remove that and add a new image map, it will be called just Image_Map. Add some more and you'll have Image_map_2, etc. You can also see this with trans maps. When you first enter the room, they're called, um, "Transparency_Map" I think, but again if you remove the original and add a new one, it'll become "Image_Map".
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
![file_120544.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_120544.jpg)
Here's a quick render of the toon puppy using daz's color map hooked into the light and dark colors of the toon shader. One light. Anisotropic highlights on the corneas, glossy on the nose.
