Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 19 7:23 pm)
That's coz you're looking thru the camera, Dizzie. Switch to the AUX cam and you can see them :o)
Thanks, ernyoka1. I should have thought of that. I move visible key lights around all the time. I am finding though that the visible charateristic doesn't stick. When I switch to a different view I need to find and make the camera visible again. Since there are a huge number of objects in the hierarchy list, that takes a while. I have tried different display styles looking for the quickest redraw that is still useable. I'd like to use a multiple view window too, but even with the smaller window size the redraws are worse.
My Store - My Gallery - My Freebies - My Web Site
But Dizzie... Now you haven't made anyone BUT the AUX camera visible, at least from the look of your hierachy. Look thru the AUX cam, then try swithing the Face cam or main cam on and you will see them. I promise :o)
Not in the hierachy editor, R_Hatch. On my screenshot I'm looking thru the AUX cam and as you can see the Main cam is the one I've cliched on, because it was the one I tried to move around when I made the screengrab. But you're right that you have to click the little eye beside the name to make it visible :o)
Thanks! I have got to try this tonight. That has always bugged me that I could not see the camera.
LVS - Where Learning is Fun!
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=726125
I have a large, fairly complex scene with a number of figures. I need to position cameras to pose the individuals and then move cameras around to try different composition views and finally to render. The scene is actually a set where the action point is offset from the origin. I've used the fixed view cameras, top, left, etc., for orientation scaling them for a wide view and then for close-up details. The complexity of the scene means some elements obscure others during this process but their interaction means I need to keep most of them visible during the process. I've been positioning the cameras roughly with the widgets but mostly by setting particular values for the x, y, and z positions and angles. Unfortunately, this is a trial and error process and takes a lot of time. Worse, the complexity of the scene makes screen updates relatively slow, and very jumpy using the widgets. Is there an easier way to position cmaeras? I miss the visible cameras I can grab and position in other 3D apps. Thanks. Incidentally, this is for the next panel of Zos Adventure, the most recent episode of which can be seen here: http://www.renderosity.com/viewed.ez?galleryid=726125My Store - My Gallery - My Freebies - My Web Site
