Beautiful scene Sharen! I'm finishing one up now using Garees Grrrl for GIRL! And don't you just love the Alicia hair :)
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
System Ram: 8GB
Unfortunately, it seems to me that the catsuit has problems with GIRL, at least the standard GIRL. I haven't tried any of the others though. I heard they made some last minute changes to GIRL, I wonder if they broke the fit of the catsuit in doing so. Unless there is a fix, I won't be using the catsuit very soon; and may ask to return the bundle since the catsuit is the main reason I bought the bundle.
The Dress for The Girl doesn't work right in Poser 5. Again, it's the JCMs. It's a bit easier to adjust The Dress manually (the problem is mostly in the breasts/chest area, from what I've experienced so far). I can't imagine how difficult it would be to adjust the bodysuit... I may be having to ask DAZ for a refund for the first time in many years... bonni
"When a man gives his opinion, he's a man. When a woman gives her opinion, she's a bitch." - Bette Davis
Apparently from what I am gathering, it is a problem in Poser 5 and GIRL and her clothing. The JCM's don't appear to be working in those combinations. " OK reading in the platinum club forum on DAZ seems the GIRL has problems in poser 5, seems they added some JCM's to fix cross talking issues in P4 but when loaded in P5 these JCM's break which is why you are getting the weird poke throughs on the clothing." - Nanoshi
Attached Link: http://forum.daz3d.com/viewtopic.php?p=65068#65068
ExtremeThemes wrote: "When I rendered I saw that the mat poses to turn off the body parts of the catsuit are not coded properly and therefore they do not change the highlight. The do not reset the reflection map or materials to none either. Here is an example of one of the MAT poses: { version { number 4.01 } figure { material BicepSplit { KsColor 0 0 0 1 NsExponent 100 tMin 1 tMax 1 tExpo 0 } } } It should look something like this for each mat pose: version { number 4.01 } figure { material BicepSplit { KdColor 1 1 1 1 KaColor 0 0 0 1 KsColor 0 0 0 1 TextureColor 1 1 1 1 NsExponent 30 tMin 1 tMax 1 tExpo 0 bumpStrength 1 textureMap NO_MAP bumpMap NO_MAP transparencyMap NO_MAP reflectionMap NO_MAP ReflectionColor 1 1 1 1 reflectionStrength 1 } } } " You may want to do some adjusting on your MAT poses as well.I had the same problem in P5 but fixed it with the help of 3dWizard. I am sure there will be an update next week for those who bought the catsuit.
If you want to fix it yourself you can do the following:
make a copy of the catsuit Cr2 and rename it that you won't overwrite the original
Do a search on Figure 1 and replace with Figure 2
Do a search on :1 and replace with :2
Do a search for JCM - scroll down until you find Figure 2 and replace with Figure 1 and the listed bodypart ie lcollar :2 and replace with lcollar :1, Search for all JCM and replace the figure number and number on the bodypart until WordPad or any other texture editor tells you that no more JCM are found in the document. Close and save.
That fixes it. Additionally you have to set the bodymorph KneeThin and AnkleThin on the Catsuit to 1 to get rid of the poke through on the knees. the Girl loads with these morphs set to 1 by default.
I know that you are not supposed to fix it yourself when you paid for it. I just thought that might be a little help for those who can and will do it and have the catsuit working properly until DAZ gets an update to you.
Every
organisation rests upon a mountain of secrets ~ Julian
Assange
mmmmm... is that something we need to fix on the boots from the clothing pack as well? I found poke through on them, as well as having issues when rendering with them transmapped to go below her knees. The 'hooks' still show up on her thigh and higher though they shouldn't and I am no good at manually editing mat files to fix that sort of thing. Guessing it'd be the same idea as the fix for the transmaps for the bodysuit, but eh. Hopefully all these things will be taken care of by DAZ asap.
Attached Link: http://forum.daz3d.com/viewtopic.php?t=6966
There's a fix posted verbally in this thread at Daz forum for the catsuit problem in P5. :-)Tools : 3dsmax 2015, Daz Studio 4.6, PoserPro 2012, Blender
v2.74
System: Pentium QuadCore i7, under Win 8, GeForce GTX 780 / 2GB
GPU.
RDNA-Alicia Hair-and flowers
Daz Enviornments
Girl V3 UV's
Zeta Studio Sulyma.
Sharen
Message edited on: 08/06/2004 19:03
