Fri, Jan 24, 11:11 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 9:54 am)
Subject: Completley lost: Installing Files in P5
Rashida ( ) posted Mon, 09 August 2004 at 3:50 PM ยท edited Thu, 09 January 2025 at 1:19 PM
Well it seems I've gone and done it. I messed up P5 bad enough (and got aggrivated enough) that I un-installed it. I plan to re-install and start with a clean slate. But before I do that I have a question. I have smoe great bits and pieces for P5 that I would like to use. But I have no clue where to install them, unless they are self installing (such a nifty thing that). I am very new at this, I spent a lot of time working with just the basic P5 program but now I want to add the bells and whistles. Any help is much appreciated. ~Ra
Rashida ( ) posted Mon, 09 August 2004 at 3:53 PM
first rule of forums... read the FAQ... any tips not in the FAQ would still be appreciated
Crescent ( ) posted Mon, 09 August 2004 at 4:37 PM
Most of the freebies here are in self-installing .zip files these days. Most of those that don't have the information in readme files. I do have a tutorial on where things need to go, but it's missing the P5 materials. .mt5 files and their corresponding thumbnails need to go into RuntimelibrariesMaterial folder. http://www.fallencity.net/tut-posb/p-file-locations.php Hope it helps, Cres
Bobbie_Boucher ( ) posted Mon, 09 August 2004 at 5:15 PM
My recommendation for starting from scratch: install everything to temporary folders to see where things would go. Sometimes artists mis-spell things: libairies instead of Libraries, Poses, instead of Pose, etc. (Stuff with DAZ installers is usually ok. It's the zip files that can be a mess.) You can always drag and drop to your Poser folders after.
rreynolds ( ) posted Tue, 10 August 2004 at 9:51 AM
The first entry in the Poser FAQ (link at the top of the page just above the Forum banner) is my attempt at showing where everything goes.
PaulBohne ( ) posted Tue, 10 August 2004 at 2:31 PM
Well, if we are talking about Poser5, there is no need to install files into the Poser root-directory, 'cause P5 can read multiple runtimes. Means, where ever you unziped a downloaded Runtime folder, P5 will recognize it as a workable file-path. (If the creator used the right folder hierachy - see my second posting comming along as an example) Cheers PaulBohne
PaulBohne ( ) posted Tue, 10 August 2004 at 2:36 PM
Here the announced 2nd answer! CAN SOMEBOBY TELL ME HOW TO INSERT TWO PICS IN A MESSAGE?
Bobbie_Boucher ( ) posted Tue, 10 August 2004 at 9:18 PM
You might try just composing a new image based on the parts of different images. I do that a lot.
ynsaen ( ) posted Tue, 10 August 2004 at 9:41 PM
Attached Link: http://www.oddditty.biz/Tutorials/5Things.pdf
hmmmmm One could try checking out the RDNA P5 forum -- much of this is answered there (www.runtimedna.com) one could also download the 5 things pdf linked here and read through it -- to get the stuff of useful ness out of it...
