use the solo mode! This is an invaluable tool. A better alternative to a file that huge, however, is to make each part of the file separately, in different files. Then, at the end when you're ready to do a final version, pull them all in using either the file/merge... command or by saving the parts as object presets. --flick
Hi all,I really need some advise with a Bryce question.I'm working on a very detailed model in Bryce 4.0.1.The size of the model is now at 425meg and growing.My question is are there any tricks to speed up the turn around time between adjustments?Thanxx for any ideas!
