Thu, Feb 13, 10:51 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:03 am)
Subject: Can the P5 Cloth Room do elastic?
robkjedi ( ) posted Mon, 16 August 2004 at 12:27 PM · edited Thu, 13 February 2025 at 10:50 AM
Does anyone know if the P5 cloth room can do elastic? I've converted a pair of Mike's boxers to dynamic clothing and hate it when the confined group (waistband) bunches up around his waist after he's posed at the end of the simulation.
Are there any settings that could change the confined group (waistband) to an elastic group with higher frictiona nd lower streatch?
Thanks,
Rob
shogakusha ( ) posted Mon, 16 August 2004 at 12:38 PM
THe problem you will encounter is that the waistband has its own geometry and will separate from the rest of the boxers in the Cloth Room if not handled right. I have had reasonable result by making a group like Waistband into a Soft Decoration group instead of Constrained. You could also 'possibly' set up a separate dynamic group for the waistband and give it different cloth properties. I am not sure if you can do that if it is defined as a soft decoration though. Good Luck! Shogakusha
Cage ( ) posted Mon, 16 August 2004 at 11:54 PM
I found that I had to extrude the top of a garment, in Wings 3D, then assign the extruded portion as a choreographed group, in a similar situation. Then assign a non-rendering material to this new geometry. Not sure it would help, but it might be a fairly simple solution. Worked for me, at any rate....
