Tue, Feb 4, 7:23 PM CST
Subject: Vue 4 update problem
zxcvb ( ) posted Sun, 22 August 2004 at 7:26 AM ยท edited Tue, 04 February 2025 at 6:53 PM
hi all just updated vue 4 from 4.12 to vue 4.22 and it now won't load any poser 4 files , i have been useing vue for about 2 years with no problems untill the the last update and it stoped importing poser objects the moment i updated vue to 4.22:-( when i try and load a poser file vue 4 says (importing poser objects requires curious labs poser software to be installed on your computer , please locate the poser application now) poser 4 has been installed on my computer for as long as vue 4 has , when you press ok totry and locate it says (an error occured while reading poser file (error #-10005). plese contact e-on software if this problem persists) then you press ok and it says (unable to read poser file) and it give the location of the file:-( If anyone's got a idea whats going on i would be very happy , i have posted this at e-on's site , but no answer yet Thanks for any help andy
nanotyrannus ( ) posted Sun, 22 August 2004 at 9:41 AM
Andy- I don't think there's tech support on the weekends, at least that's the impression I get when posting to E-on's site. I avoided upgrading to 4.22 for precisely this reason, I had heard previously that there were some issues like this with 4.22. I would recommend you update only to 4.20, as that is the last update that really improved and fixed major bugs, and since you don't have poser 5 you don't need mover 5 which is 95% of the update to 4.22. Hope this helps.
Doona ( ) posted Sun, 22 August 2004 at 7:28 PM
I just checked my copy of Vue and I have version 4.22-02. I have Poser 5 installed and I'm not having any trouble with imports. I sure wish I knew how to work the lights, but at least I am able to import.
mouser ( ) posted Tue, 24 August 2004 at 10:19 PM
Are you using the Mover plugin, if you are you will have to update that as well. Same will go for the renderfarm.
nanotyrannus ( ) posted Wed, 25 August 2004 at 11:37 AM
There is no seperate update for mover only, it is included as part of the update to the main program, the render cows do have a seperate update though.
mouser ( ) posted Thu, 26 August 2004 at 9:11 PM
Oops your right, the Vue update includes the mover update.
